Have a used Autofab Fiberglass Hood for 92-96 Ford F150/Bronco. This is a race model hood, meaning it needs to be mounted using PINS all the way around. Does not have inner support to use factory hinges. Is primer in color, and has four holes already drilled with mounting pin locations. IN good shape, has a little spider webing on the gel coat, but nothing a little elbow grease and paint wont fix.
Asking $275
