Results 1 to 9 of 9
    Senior Member dezertnation's Avatar
    Nov 2006
    Laguna Hills
    Default Ford 9" Full floater
    Custom ford 9" housing 3.5x.250 tube 4130 with 3/16 4130 plate or truss. Comes as full floater 5on 5.5, 6on 5.5 and or 8 lug. At this price you get rear end, Truss, Hub's, Studs, and fill plug. Complete rear ends also available, but at this price your truck can be a roller. $2500.00
    949-370-9313
    Attached Images Attached Images
    DezertNation.com
    Nov 2006
    Laguna Hills
    Default Hub
    Here is a pic of the hub
    DezertNation.com
    Senior Member stemhas's Avatar
    san diego/ east county/ 91978
    y is the center of the four link not down pinion center or u build them
    Nov 2006
    Laguna Hills
    Sorry not sure what u are asking
    DezertNation.com
    Senior Member 85tacoguy's Avatar
    i think he is asking why the upper 4 link mounts are not off centered like on some equal axle length housings.
    I need: 16" Fox C/O shocks, 18" Fox bypass shocks, PM me if you have something
    No. Why are they off center? Pinion cinter is .970 to the left as u look at the housing. Seems the center of the four link is centered on that center stud. Not on true pinion center. So the drive shaft will be .970 off from pinoin center
    Nov 2006
    Laguna Hills
    4 link pivots are centered
    DezertNation.com
    they are centered off the drive shaft
    Senior Member desert_steve's Avatar
    phelan, ca
    theres pinion centered, and housing centered... depends on how you want to set it up.
    "Burn it down, burn it down to the ground."
  1. coleman full floater 64 1/2" wms to wms
    By prerun400hp in forum Parts & Accessories
    Last Post: 07-27-2010, 09:30 AM
  2. 3-link, shocks, 9"full floater, carbon fiber dash
    By jim in forum Parts & Accessories
    Last Post: 05-14-2010, 09:58 PM
  3. 9" full floater
    By sms in forum Parts & Accessories
    Last Post: 01-08-2008, 07:55 PM
  4. 9"Full floater
    By 87-RANGER in forum Parts & Accessories
    Last Post: 10-20-2007, 03:36 PM
  5. CONE 9" FULL FLOATER
    By AZRANGER in forum Parts & Accessories
    Last Post: 03-19-2007, 08:55 AM
