Results 1 to 4 of 4
    Mega Member F.A.S.T.clothing's Avatar
    Irvine, CA
    Default Ranger Beam Mid-Travel Kit plus 5.5" Heimed can be long travel.
    So I am saleing the front end off my truck that has never seen dirt since all the new key parts were installed on it.
    The Beams are forged beams cut and extended 5.5" perside with brand new pivot bushings in the beams and new ball joints that cost 300 total, due to the older beams have two different ball joints, oh and not the cheap ones either.
    The Radius arms have 1.25 heims in them and the pivots are welded to the frame, you maybe able to put a bolt through it, or you can buy my sweet SI Motorsports Radius Arm Pivots for 150.
    It has a larger coil and adujstable pro comp mx6 shocks. You also get brand new mckenzies quad straps, brand new custom steel braided brake line that has the 93+ end for the motor fitting and the 89- end for the caliper fitting. You also get steering extenders
    Thr spindles are good and the whole brake assembly has been redone with new parts (new pads, turned and cleaned rotors, etc)
    For everything here so you can mount and go $800,
    Will remove certain parts if you want to spend less.
    Only Trades I need are 14" coilover, 16" bypass, and maybe 5x5.5 rims and 35 tires but dont really need the tires unless i sale my new 33s
    Irvine, CA
    Irvine, CA
    sale pending on monday
    Irvine, CA
    sold, u can delete
  1. i beam f150 long travel?
    By c1500 in forum Truck Talk
    Last Post: 11-30-2008, 03:27 PM
  2. camburg long travel for i beam ranger
    By savagepit in forum Parts & Accessories
    Last Post: 07-27-2008, 07:02 PM
  3. '90 4x yota long travel & 10" c/o's
    By WaDeTheFADE in forum Wanted
    Last Post: 10-02-2007, 03:22 PM
  4. S10 3" Long travel kit, New
    By BAJACUSTOMS in forum Parts & Accessories
    Last Post: 08-22-2007, 04:17 PM
  5. S10 3" Long travel kit
    Last Post: 08-05-2007, 11:13 AM
