Page 1 of 2 12 LastLast
Results 1 to 40 of 67
10Likes
Thread: Home brew shocks?
    Mega Member NODNARB's Avatar
    Aug 2004
    Rancho Cucamonga
    Default Home brew shocks?
    I may try my hand at building myself a pair or two of bypasses. My main question is piston design. Can I simply scale up a 2.5" piston to the diameter I want, keeping the ratio of open and closed surface area the same? If not, can anyone guide me in the right direction? Will probably be making 4.0 or 4.5" dia. shocks if it matters.
    "I know not what weapons world war three will be fought with, but world war four will be fought with sticks and stones"
    A. Einstein
    Fastest Guy 4 Half-a-Lap DoWN4GLaMiS's Avatar
    Norco
    you need to find the percentage of flow and duplicate it per the percentage you are in larging it. or something along those lines. the port sizes and and such need to increase somewhere near the same as the increase in diameter
    When a man lives dangerous, he is not afraid to DIE. When he is not afraid to DIE, he is strangely, free to LIVE...
    Either way, good luck Sean. I'll cheer you on no matter which class you race. I am a fan.
    - Dan Vance
    Aug 2004
    Rancho Cucamonga
    Ok that's what I was looking for. Seems like the logical answer because if a 4.0 only flowed as much as a 2.5 it would have a huge amount of "closed" surface area and would be way stiffer.
    A. Einstein
    Norco
    same thing happened to multiple shock companies when they went to 3.0 and even 4.0
    - Dan Vance
    OG Member motochris's Avatar
    Ridgecrest
    Quote Originally Posted by NODNARB View Post
    I'm a bit late with this answer...
    That's not really gonna work like you think it will. I'de first look into the largest commonly available shims you can get and design the piston ports around those. If you make a giant piston with ports all across the surface...what do you do if you can't get shims to cover the ports?
    Since the goal is a bypass.... it's not going to be a big deal to have less port surface area than the ratio you are thinking of, as the bypass tubes will be there as well.
    Who's ShiTalKing? partybarge_pilot's Avatar
    Leucadia
    What he said^^^^^^ Also, if your port openings are too large the shim will deflect into them causing lots of problems..........
    Monkey fab
    Quote Originally Posted by mcdirt@1s1k View Post
    also what makes him a "pro" because hes done it for 25 yrs? well fuck me ive been taking shits for 25 yrs! does that mean im a pro shitter? fuck no i still get the beer shits!
    Greazy_Meatball! 02dangeranger2wd's Avatar
    Feb 2009
    LB
    Oh snap! Brandon is stepping it up!
    -------The wine blooded pasta eater--------
    http://www.btf-fabrication.com/ http://www.clean-dezert.org/
    1448--Watch out!!
    Leucadia
    Quote Originally Posted by 02dangeranger2wd View Post
    Oh snap! Brandon is opening up a whole can of worms!
    Fixed........
    Dirt E Dreamer likes this.
    Monkey fab
    Racer Baja_XJ's Avatar
    Bedford, IN
    The CNC lab at the college I went to is sponsored by Mastercam, Ever year they put on an "Innovator of the Future" Contest, they would tell you what you were to make and you had to design and machine it. When I was there my second year we done 1/4 scale shocks for Pablo Huffaker. That was a cool time, it really isnt all that hard to do, you just have to have attention to detail for them to work the way you think theyre going to. They arent bypasses by any means but if you set to it, you can really get creative.
    dmhrac likes this.
    Leaving nothing behind but dust
    CONFLICTIVE MOTORSPORTS #766 SPEED Energy, Overrev Industries, SPY+ Optic, Amsoil, GoPro Camera Systems, Indiana Decal Company
    Grumpy Old Man F1sleepy's Avatar
    Aug 2006
    Escondido/Cuyamaca
    What was the reasoning behind the tapered reservoir body?
    Bedford, IN
    They were built more towards eye candy than functionality. When they rated it on functionality, they just checked to make sure it worked right, not that it served its purpose in the long run
    DR Mod doyouquaxu's Avatar
    Irvine
    last i talked to brandon about this, he was most likely going to make them a solid piston. not gonna be pretty, but function > form.
    Aug 2006
    Escondido/Cuyamaca
    Hopefully he just ports the pistons instead of trying to run a 3.5-4.0" solid piston. I think he would be much happier with the results.
    Leucadia
    Solid piston....... Here comes that can of worms........
    Monkey fab
    Rape Murder Arson & Rape DuctTapeRacing's Avatar
    BLF/LBC/OC
    "It will never work"
    The faster you get into the sport, the faster you get out.
    "You said rape twice.."
    Las Vegas, NV
    better put A LOT of tubes on them..
    -Sean
    "NEVER UNDERESTIMATE THE POWER OF STUPID PEOPLE IN LARGE NUMBERS!!!"
    Irvine
    He has like 6 valves, I think 4 comp/ rebound and 2 gold valves
    Las Vegas, NV
    that won't be enough...
    -Sean
    Aug 2004
    Rancho Cucamonga
    I thought this thread had died, thanks for the responses so far, I do still plan on doing this, because it's the only way I can afford big boy parts. I can machine each piece as I can afford it instead of buying all at once. Not planning on solid pistons anymore though.
    Plus, I'm really pretty dense and have to learn lessons the hard way. It's not always more fun, but it is more interesting that way.
    I'm going into this knowing it'll probably cost more in the long run and make me bang my head against the wall a lot, and I'm ok with that.
    TheTequilaWorms likes this.
    A. Einstein
    Aug 2004
    Rancho Cucamonga
    Ok, so I'll be using 2.75" shim diameter. Making pistons with an angled top.
    Flow will always be restricted to the smallest part of a port, correct?
    What I mean is, say the port starts at .500" and then opens up into a .625" at the end, it will act as if it has a .500" port all the way through, correct?
    Thanks for any replies.
    A. Einstein
    Minot, North Dakota
    As I still have a lot to learn, why would you do it that way? Does it kind of act as a funnel effect?
    Aug 2004
    Rancho Cucamonga
    Quote Originally Posted by 04yfzkid View Post
    I don't think it does, flow should be limited by the smallest part of the port, like a bitchen exhaust system behind shitty exh. Manifolds.
    Have to enlarge some parts of the ports to
    Clear the shims to allow flow on rebound.
    A. Einstein
    Racer maxyedor's Avatar
    10,000 Oaks, Ca
    Shocks have always been on my list of things to build, just to say I did. My plan was to start with some off the shelf pistons and go from there. I will never know enough about fluid dynamics to build a better piston than King will sell me for a price that's considerably lower than having it machined to my specs. Considering the deals I've gotten on shocks, it definitely wouldn't be cheaper to build my own, but it would be fun.
    Quote Originally Posted by Only1Mikey View Post
    You know what's cool about doing a lincoln locker on race day? You don't have to worry about warming up the gear oil.
    OG Member TRD SRP's Avatar
    if you want a shock to last roller burnish the cylinder its cheap and cuts out all the friction and make the cylinder as smooth as if you where to gun drill it i do this on all my cylinders i build and its cheap
    every shock i have ever seen is a joke inside the tolerances are a joke i to have thought about building some that where adjustable from in the cab all manually no electronics i have come cool sure seal valves i build for another industry i sell to that would work great and could have 12 different settings from in the cab
    emptyzrider likes this.
    srp
    2000prerunner
    Jul 2003
    Escondido, CA
    I don't understand what you wrote.
    Why would you not run Twin Traction Beams?
    I think FOA (possibly RadFlo) already made some driver adjustable shocks for the KOH guys.
    Quote Originally Posted by TRD SRP View Post
    "It is the mark of an educated mind to be able to entertain a thought without accepting it."
    -Aristotle
    Leucadia
    Quote Originally Posted by 2000prerunner View Post
    It's a type of finishing for the inside of the tube. The tools has what looks like dowel pins around the outside. As it goes through the tube it spins and the rollers slightly compress the surface to the metal leaving a nice smooth hard surface.
    You can also buy hydraulic cylinder tubing that is honed. As long as your careful welding these make very nice shock bodies.
    Monkey fab
    FOA has done it
    foa did it way different then the way i have designed it and they cost so much it was not practical bilstein did it about 6 years ago and cost over 20 grand for just two shocks that where electronic controlled
    srp
    are you saying your way or FOAs way isnt practical?
    foa and bilstein
    srp
    the FOA ones im referring to arent electronic or cost anywhere neat 20k.
    Leucadia
    There was a truggy at Laughlin years ago with Kendall bypass's on it. They had a ball valve on one of the tubes to control flow. There was a small Morse cable running from it to a lever in the cockpit. Adjust on the fly.......
    Monkey fab
    Aug 2006
    Escondido/Cuyamaca
    From the pictures I saw of the in cab adjustable FOA bypasses, I want to say that's what they did also.
    Her name is Dielila vvvv WannaB-Class5's Avatar
    El Segundo CA
    Electric gate valve from home depot
    Find a way to ensure it can hold up to the pressure it will see
    Profit!
    Just like everything offroad, it's going to break/fail, it's just a matter how and when.
    Quote Originally Posted by F1sleepy View Post
    FOAs is cable operated, but not exactly the same.
    Senior Member solidus's Avatar
    where are the pictures of the FOAs I would love to see that set up.
    In case you've missed it the first 1000 times..... YOU, Sandfreek, SHUT YOUR GODDAMN GINGER MOUTH YOU SOULLESS WASTE OF SPACE!!!!!! No one here gives a two schilling shit about what you have to say.
    I imagine rounding them all up and yelling "AutoBots, Roll Out!".
    Minot, North Dakota
    Quote Originally Posted by solidus View Post
    Like FOA on facebook, they just posted some pictures the other day. Sorry I'm too lazy to find them for you lol
    foa are junk
    srp
    Kyle Shapiro LVbLaCkRaNgEr's Avatar
    las vegas
    TRD SRP suck it douche bag!
    84prerunner likes this.
    www.f-o-a.com
    Shock Technician
  1. Replies: 0
    Last Post: 10-20-2010, 07:56 PM
  2. I need a Home
    By rangerrunnin in forum Other
    Last Post: 10-05-2010, 08:49 PM
