Limit Straps have been around for a long time and they used to be very reasonably priced. Over the last few years increased demand has I driven up the price to the point I am doing something about it. When I was in college a friend of mine owned a small company sewing climbing equipment (A5 Adventures), now and then I worked for him and learned a thing or two about just what it takes to make webbing stay together.
We are bringing that kind of quality to our Limit straps. We only make Quad Straps because I see no reason to go any lighter. At Ruffstuff we also know a bit about steel and the ends of our limit straps are NOT 4130 Chromoly like one of our competitors advertises there's to be. The straps would tear long before 3/16" mild steel would, even with our 7,000lb Mil-Spec nylon. Chromoly in this case is just a catchword to get your attention and make them more expensive.
We use a gold zinc plating on our ends and they also have a built in deflector that spreads the load over a greater area for less wear and a longer life. We offer the Limit Straps alone or a kit including the weld on ends for the axle and chassis.
You can buy them alone for for $23 in lengths from 12" to 32" or with the weld on brackets for $29 ready to go!
Dan Fredrickson
www.ruffstuffspecialties.com
Products that are better than "Good Enough"
Sales 916.509.2242 Tech/Sales 916.600.1945
Check out our Axle Housings & Heims!
