Results 1 to 3 of 3
    Senior Member mxr181's Avatar
    Fullerton
    Default 97-03 F150 8.8 LS axle 3.55 (disc brakes) and other F150 stock parts
    Im making a socal run for the weekend will be leaving wed night after work...I have a used limited slip 8.8 axle with brakes, it needs spider gears but they are cheap and easy. Otherwise in good shape. Its on craigslist for $300, but Ill make someone on DR a better deal...also have the rest of these parts:
    Heres a copy of the CL add:
    2002 f150 8.8 Rear Axle, has 3.55 gearing and Limited Slip. In good shape except it will need new spider gears, but they are cheap and easy to install. $300obo
    All steering items minus pump - $make offer
    ABS controller - $50
    Cruise Control module & cable - $40
    4.6L MAF - Mass Air Flow sensor - $40
    spare 4.6L V8 PCM / ECM / Computer - $50obo
    Gauge Cluster, computer, ignition & key (can sell as a matching setup so PATS system will be happy) - $300 or sell separately
    Engine harness, dash harness, all wiring, etc
    Stock throttle bodies from 2002 4.6L & 2000 5.4L $40 each
    4.6L water pump, was replaced about a year ago, probably only has about 5-10K miles on it, also includes fan because I couldnt get them to come apart - make offer
    Stock Brake booster $100
    One stock front brake caliper - not sure which side but will figure out asap. Also have a new set of brake pads as well. Make offer
    ***The best way to get ahold of me is to call / text 916-996-2192 or email. Also I can get you better pics of specific items
    Fullerton
    BUMP! will take $150 for axle...need it gone!
    Senior Member swick's Avatar
    porterville/chico
    what is the wms of this axle. if this axle has lsd then it does not have spider gears. would my 15in rim fit over the breaks.
  1. 97-03 F150 8.8 LS axle 3.55 and other F150 parts
    By mxr181 in forum Parts & Accessories
    Last Post: 08-04-2011, 11:23 AM
  2. Complete Trussed Tundra Axle 4.56, LSD, Disc Brakes
    By jonsangel in forum Parts & Accessories
    Last Post: 03-18-2011, 08:48 AM
  3. Parts sale, shocks, disc brakes, CST, etc
    By Idahos10 in forum Parts & Accessories
    Last Post: 03-02-2011, 02:11 PM
  4. FS 97 Explorer axle, gears & disc brakes
    By dan in forum Parts & Accessories
    Last Post: 08-17-2009, 05:46 AM
  5. Disc Brakes for Explorer Axle
    By icdred in forum Wanted
    Last Post: 06-05-2007, 08:28 PM
