Results 1 to 20 of 20
Thread: Squeaky
    OC
    Hey guys what's going on. I'm new to the board posting wise but have been watching it for a while. Ok so here is my question: Lately my breaks have started a high pitched squeak. I took of the tires and sprayed degreaser and what not on the disks, but am not to familiar with drums. The only thing throwing me off is; when I am just rolling along, it's still squeaking, no brake compression at all. The brakes aren't very old at all so could it either be;
    1.Dirt and moisture from my last desert trip.
    2. Something else, hah.
    It's a 95 4.0 Ford Ranger. Any help would be awesome. Also, if anyone has diagrams on the removal/cleaning of drum brakes that'd be greatly appreciated too. Sorry for the long first post. Thanks again.
    Hi.
    old matt_helton's Avatar
    Yorba Linda, CA
    front brake possibilites...(assuming your pads are new like you say)
    1. stuck caliper which is causing a pad to drag on the rotor which over time had caused a hot spot which makes the squeel
    2. a rock or debris in one of the pads,
    3. a bent wear indicator that is contacting the rotor at all times.
    rear brake possibilites.
    1. shoes worn down to the rivets.
    2. debris or a rock stuck in the shoe.
    3. broken spring spring causing the shoes to drag.
    pull the drums and check it out. shoot some break clean in there and look for broken hardware/springs and or deep grooves/gouges in the drum surface or hot spots from debris.
    G-ville, NC
    Jack the truck up and have both front tires off the ground. Then check for play by shaking on the tires side to side. You might have fucked up ball joints.
    Yorba Linda, CA
    could be dirt in the wheel bearings. throw your center caps back on, or put the covers back on your stock wheels (if you took them off) after you re-lube your wheel bearings. see if that fixes it.
    do what pirate suggests, if the spindle shifts from side to side, its your ball joint, if the spindle doenst shift, its just your wheel bearing that is loose... just tighten it down... it might be a good time to replace the bearings too...
    \"either way, its a complete cluster fuck, in typical GM fashion.\"-Helton
    Cluster fuck driver for life!!!!
    Support your local fab shop... Keith Sato @ OC OFFROAD 714-744-1288
    Yorba Linda, CA
    WTF PEOPLE..........
    san clemente, ca
    matt i dont think any of your of your possibilities are even close to what the problem really is. its the balljoints for sure,they always sqeak when bad,especially rolling straight and not turning the wheel while brakes are not applied.
    the rear is a solid axle too
    Yorba Linda, CA
    lol...
    Corona, CA
    Yeah, my balljoints squeek like a MFer. *sigh*
    Project unfinisher BRUUUP's Avatar
    Aug 2004
    Simi Valley and 818
    im so lost by that......
    muffler bearing?
    I hate your sig........
    Quote Originally Posted by SF@DERTCO View Post
    So what your saying is the phone knows your stupid and is tired of correcting all of your mistakes??? Is that what im getting out of this info????
    Senior Member DilutedImage's Avatar
    Sun City, CA
    Quote Originally Posted by [b
    Quote[/b] (matt_helton @ Jan. 17 2005,9:45)]WTF PEOPLE..........
    My thoughts exactly ....
    First things first, I'd try the things Matt has suggested ... Most of these replies seem to be ignoring the part where the DRUMS were cited as the culprit. ... 2¢
    - rising up against this wickedness -
    G-ville, NC
    Actually he said he "sprayed cleaner on the discs" and wanted to know more about the drums. My truck had the same problem. I checked the brakes and they were fine. Then I realized it was the balljoints when I checked for play in the front tires. I replaced the balljoints, problem solved.
    Sun City, CA
    Haha, I missed that part .. .Whoops! .. Still, I would begin by checking the drums, as they have not yet been checked ... I'm bettin' my money on dirt being in there ... . 2¢
    OG Member OC96Ranger's Avatar
    On the flip side
    He said he didn't know how to remove drums though.
    I'm Dave
    Senior Member motoxxxprerunnerranger's Avatar
    southern california
    my ranger has done the same, it was actually loud untill i hit the brakes.. i just used my pressure washer and blasted the front rotors and calipers and it stopped, it probably has dirt/brake dust. after blasting it black/brown water ran out and it was fine, try it, even with a gargen hose, try to get a nozzle that emultaes alot of pressure. dooo ittttt. matt what the hell are you thinking. lol.
    ODR Off-Road Racing Fabrication
    Redlands, California
    apple drink? its GREEN!
    OC
    That was my other plan. It now sounds like a fucking rock imbeded itself in the brake pad hah. Day off tom though, I'll figure it out.
    Hi.
    Newport Beach
    are you all fucking smoking shit? its obviously the spark plugs and the flux capacitor. sometimes when the flux capacitor reciprocates, it will cause the blinker fluid to run low...so make sure to check all that,a nd it should do the trick
    his majesty, ivan the terrible, last action hero, leader of the sack, love wand, main vein, man pole, man root, master wang, magic johnson, murkey lurker, mushroom tipped love dart, admiral winkey, ankle spanker, the bald avenger, baloney pony, battering ram, bavarian beefstick, beaver buster
    TFD
    TFD is offline
    not finna get got TFD's Avatar
    Jul 2004
    Chula Vista
    unnecessary.
    Quote Originally Posted by Random Grimey Black Guy
    Now freak that bitch out tron!
    Quote Originally Posted by Peter Ackerley View Post
    PROBABLY not. I live by myself in a caravan park.
    Senior Member mxking426's Avatar
    Sep 2003
    Quote[/b] (TFD @ Jan. 22 2005,7:47)]unnecessary.
    Whats unnecessary. Him making a joke or you unnecessarily posting unnecessary? :
    OC
    Ok welp, it's gone to hell. Honestly sounds like a rock scraping against metal. Can't tell if it's front or back. Had the rotors replaced not too long ago so I guess I'm taking it back to the douche who did it. Meanwhile, can someone either explain or send me a diagram showing how to remove drum brakes. Would be GREATLY appreciated. That, or come over and fix it haha.
    Hi.
    Senior Member Socalsixpack's Avatar
    The Armpit of Riverside County
    Quote[/b] (Sharp @ Jan. 23 2005,5:08)]Ok welp, it's gone to hell. Honestly sounds like a rock scraping against metal. Can't tell if it's front or back. Had the rotors replaced not too long ago so I guess I'm taking it back to the douche who did it. Meanwhile, can someone either explain or send me a diagram showing how to remove drum brakes. Would be GREATLY appreciated. That, or come over and fix it haha.
    Removing the drums is pretty simple.
    1.) jack up rear
    2.) remove wheel
    3.) grab the dum and pull, make sure the e-brake is not on
    4.) inspect shoes and inside of drum
    From there, take a good look at it. It's all pretty common sense stuff. There should be a decent amount of material left on the shoe, if not you need to replace those.
    I'd suggest you pick up a Chilton's manual for your truck. You can find it at Kragen, maybe Vato Zone or Pep Boys. You'll save a lot of time, headache, and money that way.
    4 cylinders of fury
  1. squeaky shocks
    By gcd craig in forum Truck Talk
    Last Post: 07-25-2007, 10:47 AM
  2. squeaky heims
    By -soLitaire- in forum Truck Talk
    Last Post: 09-01-2006, 11:00 PM
  3. help squeaky front suspension
    By in forum Truck Talk
    Last Post: 09-07-2003, 01:58 PM
  4. squeaky situation
    By toyotaguy in forum Truck Talk
    Last Post: 09-04-2003, 07:56 AM
  5. help squeaky front suspension
    Last Post: 09-03-2003, 10:02 PM
