What do you think about building up a 4runner with some deavers and some res/bypass shocks all around? Pros? Cons? You think it would be better to start with an a arm truck? You think with some motor work you could keep up in 1450?
2003 silverado camburg everything
2007 crf250x
2008 crf 450x
I thought all 4runners had a-arms or are you proposing to put leafsprings up front as well? Regardless, any truck can work well with a correctly tuned suspension and some cash. Look at Leduc's solid axle jeeps. Those work pretty damn well.
-Tim
04 F150 -DD
89 Bronco -Chase/Trail Truck
#363
Only the 84 and 85 4runners have solid axles all around. 86 and on they have a-arms.
yeah, 85 was the last year for SFA. It was also the first year for EFI. All yotas 86 and newer are a arms.
More opinions please! Thanks much.
2007 crf250x
2008 crf 450x
i wouldnt bother with the SFA. you would probly be best to find some rockcrawler to buy it from you. they love those trucks. then with the money buy a 2wd a-arm toy. the 4x4 a-arm trucks are solid but have considerably less ground clearence than the 2wds.IMO
\"That truck is gangsta!............. What is it?\"
