Results 1 to 20 of 20
    Senior Member 1984ranger's Avatar
    hemet
    Default power steering going out??
    i got a 84 ranger and whenever i get my truck in the mud or when it rains if im at a dead stop sometimes i cant turn my steering wheel.kinda like my power steering just cut out then when i start moving it kicks back in ,anyone have a clue on what this is?
    do you mean you really cant turn it, or that its really hard to? without power steering, its really hard to turn the wheel when youre not moving.
    if you really cant turn the wheel, i dont think its your PS system
    hemet
    i can turn it,but its really hard to its wierd.but it makes a screamin noise while im turning it
    50mob!!! mobbing50s's Avatar
    Garden Grove
    check the fluid and for leaks
    hemet
    its fine the fluid is topped off and there are no leaks at all
    your power steering fluid might be low, or your belt could just be loose causing that screaming sound you mentioned.
    hemet
    it usually only screams when i turn it all the way one way
    Member t-dog007's Avatar
    escondido, CA
    yeah my 2000 ranger did that for a while. i did a power steering flush at work and i couldn't believe how dirty the fluid was that came out of it. try that and see if that doesn't help your solution any.
    hmm, that cant be good. what does the fluid look like? is it really dark and smells extremely burned?
    escondido, CA
    lol no it was kind of milky. like moisture got in there or something.
    2000 XLT with BMS LT kit
    Senior Member mcyota7200's Avatar
    Corona, CA
    It sounds like you just need to get your system purged and flushed. But before you do that, check your belts, hose connections, etc. Also you could try to get any air bubbles by turning the wheel full both ways to full lock at least 10 times as fast as you can. Sometimes it's easier to disconnect the steering linkage from the pitman arm so you can turn it faster make sure the engine is running.
    If after doing the purging thing and the fluid is foamy or milky you need to replace it.
    Senior Member wpmxwb's Avatar
    Long Beach, California
    sounds like the belt is getting wet and causing it so slip. used to have that problem on my k5
    hemet
    haha i looked at it today and it was milky white an was low as hell that might be it lol change it and have no problems now
    You mite want to change it and drive it a little then change it again cuz milky white usually meens theres water in it
    Senior Member bigdognathan's Avatar
    san jacinto, ca
    thought i'd bump this instead of creating a new thread.
    my 95 ranger came with manual steering. i just installed pump, bracket, power steering gear, hoses. all used parts. now my pump is loud as hell. i rebuilt the pump with new seals so it doesn't leak at all now. but when turning it gets really loud. granted i am running 35's but does any one else have problems with there pumps running big tires? after reading the info above it sounds like it could use a flush because the old fluid looked milky. might get it done this weekend.
    "just doin my part to make this world a better place. one truck at a time. haha" - kelly @ KFC
    05 ford f-150 super crew..........pro comp 6" lift, 35" nitto terra grapplers
    hemet
    yah well mine isnt that loud anymore but when ever i offroad it gets really loud. i think i just need a new pump. did u use right power steering fluid? and did u bleed the lines?
    i've got 32x11.5 and it can turn them without much effort. i can back out of a spot, stop/turn to full lock the other direction without much noise from my system except for the normal wurring noise of the pump.
    if its milky it meens there is air in it. and use atf
    Senior Member lb295's Avatar
    Jul 2008
    yorba linda
    my truck does that sometimes when i hit a puddle or something. im pretty sure water gets on the belt and slips.
    and how do i go about changing my ps fluid
    hemet
    what i did was i already had a small pump so i sucked all the bad shit out and put new fluid in and therefore i would not have to bleed it.
  1. No power steering, but want it.
    By rockstar in forum Truck Talk
    Last Post: 01-03-2008, 05:33 PM
  2. power steering?
    By heelflip131313 in forum Truck Talk
    Last Post: 06-11-2006, 09:24 PM
  3. power steering
    By nubiyotaman in forum Truck Talk
    Last Post: 06-06-2005, 11:25 PM
  4. power steering
    By EmpirE231 in forum Truck Talk
    Last Post: 04-30-2004, 12:25 PM
  5. power steering
    By NeverLift in forum Truck Talk
    Last Post: 03-13-2004, 02:00 PM
