Results 1 to 5 of 5
    Custom User Title urandaman's Avatar
    Sep 2004
    CO
    Default removing airbag on ford ranger
    removing bolts is no problem, but what all has to come out to remove the air bags from a Ranger?(2007) should i disconect the SRS module that is on the transmission hump?
    obviously disconnect the battery and let it sit for a while to drain any stored up energy.
    once air bags are removed, will the truck still operate the same, except for the airbag light being on?
    old matt_helton's Avatar
    Yorba Linda, CA
    just unplug the fucker and take it out. if you are really scared then pull the SIR fuse first.
    and yes the truck will be fine afterwards. youll just have the light in the cluster on all the time.
    Mega Member sparkypyro's Avatar
    Hermosa Beach, CA
    Blow that fucker in the street. With a trash can full of water on top. Or sit on it THEN blow it.
    DISCLAIMER: That last one would be pretty stupid to do but if you decide to try please record it.
    Racer SF@DERTCO's Avatar
    Nov 2006
    Get a postive and a negitive and touch them together on the airbag.
    Tempt Media Digital Cinema
    Shot on RED
    TOYO TIRE/JAMAR BRAKES/MOMO/RIGID INDUSTRIES[/b]
    Sep 2004
    CO
    ha well i got it removed, it was only 2 bolts and a plug.
    the dash on the other hand was a PIA.
  1. 02 ranger airbag
    By DirtKing fabrication in forum Stock & OEM Parts
    Last Post: 04-09-2009, 07:33 PM
  2. removing body lift from a ranger???
    By burDom13 in forum Truck Talk
    Last Post: 03-15-2009, 01:59 PM
  3. Airbag for Ranger
    By Toyota 4x in forum Truck Talk
    Last Post: 07-07-2005, 09:37 AM
  4. Ford ranger airbag
    By RP@CRAFT in forum Parts & Accessories
    Last Post: 08-01-2004, 04:18 PM
  5. Removing Ranger Dash
    By monkeyseemonkeydo in forum Truck Talk
    Last Post: 07-09-2004, 04:51 PM
