Results 1 to 34 of 34
    Custom User Title urandaman's Avatar
    Sep 2004
    TX
    Default installing a fuel cell
    this is the next step with my truck, and im not sure what parts i need to get this done. what are all the parts big and small that are needed to correctly install a fuel cell? it is going in a 4.0 sohc ranger, and i will be ditching all factory stuff so i do not have to deal with that headache.
    i will be only doing this once so even if the parts are expensive i would like to do it right. if something has to be setup a certain way to be race legal, feel free to point that out also.
    also would like to have a fuel gauge, even if they are not 100% accurate, it will give me an idea.
    OG Member Red Star's Avatar
    In your girls bed.
    Call DezertNation ask for Rob. He will hook you up with all the parts, fittings etc you'll need.
    "riding in a linked truck is like riding a black man" -85yota
    Her name is Dielila vvvv WannaB-Class5's Avatar
    El Segundo CA
    Qualitly fuel pump and filter. Sending unit and guage designed for said sending unit. Fuel lines and AN fittings. Somewhere you will have to tie into your stock fuel system which can be simple or you can go exotic. I have only done this twice so I am no expert, but us dummies got it done no problems. Load ass Chevy fuel pump though!
    Just like everything offroad, it's going to break/fail, it's just a matter how and when.
    Racer sirhk100's Avatar
    Feb 2003
    IMO, buy a fuel cell... Pull the sending unit and pump out of your OE fuel tank and retro fit it into the cell!!! Must headache free way of doing it. Going aftermarket fuel pump is my biggest regret on my truck! Although, whenever it doesn't run or it dies on me, I always know what it is!!! LOL
    Khris
    Sep 2004
    TX
    i have heard some people have had problems with using the factory sending unit.
    if i went that route, would it be race legal?
    i obviously dont care about keeping the truck street legal per CA laws, as it is registered in TX and will still be legal there.
    Racer dezbombin's Avatar
    Jun 2003
    Quote Originally Posted by sirhk100 View Post
    Thats how I did mine. Also keeps your stock sending unit/gauge working.
    In fact I have a 22 gal jazz all setup for this for sale.......
    and yes mine was race legal.
    Hell, Ive got tools to fix tools...C'mon bitch, break somethin'
    Sep 2004
    TX
    i will have to look into that.
    i am going to go with a 32gallon cell, would the stock sending unit still read correct with that size tank?
    if ditching the factory gauge cluster, would the factory sending unit hook up to an aftermarket gauge also?
    Feb 2003
    Quote Originally Posted by urandaman View Post
    All you would possibly have to do is shorten or lengthen the fuel pickup tube and also the sending unit lever. Pull the pump and sending unit out of your tank and look at how they work. It'll be pretty pretty obvious what you need to do to modify them to work.
    Then just pop holes in the canister and bladder, make some gaskets and bolt them up!
    Way cheaper, way more reliable, a little more work! Wish I had gone this route to be honest!
    Khris
    In your girls bed.
    ull need to modify the stock sending unit. but going with an aftermarket quality pump setup is just as easy, if not easier. Just do it right the first time.
    Sep 2004
    TX
    Quote Originally Posted by Red Star View Post
    ha just trying to determine which way is the "right" way.
    Jun 2003
    yeah you just have to get the right ohms range which I forget.
    There are pros and cons to each setup. If your on a budget I would definitly use the stock stuff for now. Aftermarket Pumps, filters, lines, regulaters, an fittings etc etc, add up QUICK.
    Feb 2003
    There's a few of us that have had nothing but issues for years with the aftermarket pumps that are available and commonly used. The kartek pump is crap that's for sure! I've tried it mounted above the tank, below the tank, horizontal, vertical, with a pre filter, without a pre filter, It still fucks up on me occasionally. I have no faith in it... Now I'm running an autozone pump that's similar but it still has it's issues. Only way I've been able to get the system reliable is with it mounted horzontal above the tank. The catch with that is it's the highest part of the system in the back and in direct sunlight so during the summer I get to battle vapor lock! Oh boy!
    Khris
    Sep 2004
    TX
    not necessarily on a budget, but dont want to end up spending more to change setups again.
    Jun 2003
    well the stock setup you already have so its virtually free......just buy some rubber line, gasket material, some scrap metal to extend the pickup and a couple hose clamps......
    Sep 2004
    TX
    is it hard to modify the fuel cell to accept the factory sending unit?
    Jun 2003
    no. you just have to make a new hole in it for a filler. the stock sending unit just happens to fit perfectly in the jazz filler hole. heres a pic of truelines
    OSHA approved JakeP's Avatar
    I believe this thread had some more pictures, but it should help even though it has some smog stuff too. street lega fuel cell
    8/14/2010
    ==Only the ones like us that were there and lived the event will understand.==
    Clean-Dezert.org hxckidd's Avatar
    Feb 2002
    so cal
    bitter party of one. lol
    "adam im done even listening to you... your a hipocrit and more and im not going to even acknowledge you anymore... please dont start crap in this guys thread... "
    FTW
    Tin Foil Hat Brigade NeverLift's Avatar
    NB, PRK
    Get an Aeromotive pump and filter, and quality ss line with a/n fittings, thats what I did but minus the Aeromotive stuff. But if I were building another prerunner thats the route I would go, oh and I would run a redundant filter and pump setup. Shit sucks when that stuff goes south when you in the middle of nowhere, especially Mexico.
    Mega Member garagebuilder's Avatar
    Brea, CA
    your truck will require a lot of regulator bs to get the fuel pressure correct unless it has a stock return line from the fuel rail to the tank.
    this is what i plan on doing when the time comes for a cell for my truck:
    custom cell with fuel safe pickup/breather/fill plate
    surge tank that houses stock oem ford sending unit outside of the cell fed by a carb fuel pump (high volume low pressure)
    the surge tank is 100% sealed, so the draw from the oem pump is consistantly fed by the cheap high volume pump.
    the surge tank/ pump housing will be constructed out of aluminum tube capped on one end and a flange to bolt the oem sending unit to on the other.
    the only new fuel lines will be from the new cell to the surge unit, and no new wiring needed.
    Senior Member bigdognathan's Avatar
    san jacinto, ca
    that sounds like an awesome idea.
    "just doin my part to make this world a better place. one truck at a time. haha" - kelly @ KFC
    05 ford f-150 super crew..........pro comp 6" lift, 35" nitto terra grapplers
    senior member cam9's Avatar
    hesperia, ca
    not to hijack the thread, but im also in the middle of mounting a cell in my yota right now. would i be able to do the same with my stock yota fuel parts?
    Feb 2003
    Quote Originally Posted by hxckidd View Post
    So!!!
    Quote Originally Posted by cam9 View Post
    Yes
    Khris
    Senior Member murphco's Avatar
    Oct 2003
    az
    khris is getting close to greg status!i thought the same thing about the stock pump so we tried 2,they both fell apart or stopped working.i used a bosch pump and made the fittings(back then they werent an over the counter thing) and it is still on the truck and working 10 years later.just make sure to put a filter in front of the pump and to try to put it below or as close to below fuel level at its lowest.khris the black truck did the same thing with the vapor lock,we put a piece of aluminum over the pump with better results.what fixed it was a small piece of aluminum under the fuel rail on the engine,i carried a bottle of water and sometimes poured my soda on the rail or bled the rail for a second to get it going it worked.
    Senior Member PigRacing's Avatar
    San Diego, CA
    I have a couple questions to add:
    Are there fittings to convert from an to a stock ford fuel pump? If so who sells them?
    Is there a trick to removing the filler neck from a jaz cell? I un-bolted the nuts around it but it's still attached some how...
    86 Ford Bronco II
    4.0L -> C5 -> Manual 1350 -> Dana 28/Ford 8.8
    I think of every little nothing
    That we could own
    To overthrow all of you
    Who have overgrown
    Jun 2003
    Quote Originally Posted by PigRacing View Post
    pretty sure(fuel rail for sure, arent they the same? I used regular high pressure line and dual hoseclamps), jegs has the fuel rail fitting.
    the bolts are tight, shimmy it off.
    Random and offensive slcpunk74's Avatar
    WB,UT
    I heard somewhere that the bronco II's had an inline pump that some guys were using. If it works I guess it would be cool because you can get one damn near anywhere and they would have a warranty from vatozone or whatever.
    Feb 2003
    Quote Originally Posted by murphco View Post
    LOL, just completely over the stupidity and egos on this forum! That's not commenting on anything in this thread... Just in general!
    Khris
    Oct 2003
    az
    im right there with you trust me,its out of hand and seems to be getting worse.admins have their hands full,they should have robert help out.
    Racer PaulHayslett's Avatar
    Dec 2005
    BAKERSFIELD CA
    hey eric mine is set up for stock ranger fuel pump that has been modified to plug and play...u can buy mine as i need to get a different cell for my motor set up...call me we will work it out
    MORE 1419 Snore 1499 Taco with a side of Beams!
    Trinity Motorsports
    PolyPerformance.com
    Powered by Jesus!
    Cheap aint good and good aint Cheap!
    Sep 2004
    TX
    get me some measurements of your cell paul, im trying to stick it under the tires. may end up putting it behind the cab tho.
    zac
    zac is offline
    Senior Member zac's Avatar
    May 2006
    arkansas
    Quote Originally Posted by slcpunk74 View Post
    I could have been misinformed of what it was off of when I bought it at autozone but I think it was from a late 80's fullsize bronco, and was just an inline pump. Maybe everyone already knows that, dunno, but I ran one on my S-10. Like you said the best part was the lifetime warranty and availbility.
    zac
    Oct 2003
    az
    Quote Originally Posted by zac View Post
    my 86 bronco had a pump in the tank and one in the frame by the trans,one pusher pump and one for pressure.it made the fuel system lame with the plastic discriminator fuel filter housing.the pump on the frame would probably work on its own but i would put it as close to the cell as possible.
    zac
    zac is offline
    May 2006
    arkansas
    That's probably the one then, I ran it for 3 years with no problems, but it was never offroad.
    zac
  1. Fuel Safe 12 gallon fuel cell
    By Krezer in forum Parts & Accessories
    Last Post: 01-13-2008, 11:14 PM
  2. fuel cell w/fuel pump and auto meter fuel guage
    By deluxfab in forum Parts & Accessories
    Last Post: 03-23-2006, 02:20 PM
  3. 70 Gallon Fuel Safe Fuel Cell
    By Grampsride in forum Parts & Accessories
    Last Post: 07-20-2005, 12:21 PM
  4. external fuel pump for fuel cell...
    By minitacoma in forum Wanted
    Last Post: 03-10-2005, 07:51 PM
  5. Installing Fuel Filter
    By BlueRanger in forum Truck Talk
    Last Post: 03-12-2004, 06:04 PM
