'06 Ranger Build
taintstick
Sep 23, 2020
24
12
the deep south
Before I took a week off of work and went to the island, have not gotten much done. Since I have no help with lifting the diff out the truck, had to scoop up an engine lift...
221433
221434
themoneypit
Jul 30, 2018
288
292
Missouri
Stock master works just fine with the Explorer brakes. Apart from correcting the spring perches, it's a bolt-in affair. Can even keep the e-brake if you choose to.
Reactions: taintstick
taintstick
Sep 23, 2020
24
12
the deep south
From an earlier post about an abrasive blaster/compressor, I made the time to test it last night. Both are different sides of the diff but the rust was the same.
221435
221436
cp300
Nov 5, 2016
12
4
I am curious, what did you do about the brake line set up? Assuming you had drums before your swap like i have, i read somewhere that you can link the brake set up without having to convert everything.
Those brakes are definitely sweeeet! for the moment, i will be going with some regular brakes instead of drilled/slotted.
The brake line set up is completely different, Had to buy new brake lines and do some custom bends
taintstick
Sep 23, 2020
24
12
the deep south
Working on cutting off the mounts and whatnot, would like some input as I just want to be sure I’m doing this correctly.
first photo is starting out second is a bit cleaner. But still need a bit go I think to knock them off
221475
221476
96f-u250
1,062
316
Phoenix
I think those tubes are 3/8” thick.. if you cut in a little just fill it with weld and grind and sand.
I used a cheap chinee plasma and didnt take my time. Said plasma has it own thread on its awesomeness.
taintstick
Sep 23, 2020
24
12
the deep south
I’ll keep going at it then, I am no welder but I did buy a flux welder to learn. But when I take it to get the new perches and mounts put on I’ll ask them to fill in the gaps if I cut too deep. Appreciate it bud!
