2,278
2,086
Radiator does not have a heat exchanger in it or i would use that. I should be able to find a spot for it up front. Won't be direct air flow but with the fan should work good enough and be better than not having one at all.
Idea was you could use the heat exchanger then use a smaller cooler with good fan anywhere up front out of direct air flow to help knock down the temp some more. Guess you can try her out and see what happens!
10,387
1,576
2,278
2,086
I got one of these that i'm not going to be using and I'd sell it for $110 shipped if interested.
I appreciate it tommy but I get the Allison coolers free and already have a spal fan for it. Just need an adapter off the oil filter port
Reactions: 85yota
10,387
1,576
I'm practicing more on these panels which will be covered up before doing the dash and panels that you will see. Going to get a harbor freight pipe threader and variable speed pedal to make it a power beadroller and build a little table around it so I just have to steer the panel not hold it up and steer it.
Got a few more panels tacked in for the floor/firewall. Also for the intake manifold and fuel rails that i'm running I am running the pressure regulator off the return side of the fuel rails so I had to move the mount of the alternator up to clear a fitting on end of the fuel rail. Easy little bracket moved the alternator up around 2.5" and keeps it perfectly in line just need a slightly longer belt than before.
