Ok so I got the links and radius arms all painted up. Then I got the rear axle brake lines on so I can weld the little tabs for that. I am using 3/16" stainless line with -3AN ends as well as the same length soft brake lines everywhere on this truck, front and back of links, radius arms, to all 4 calipers etc, so I can bring a couple spares just incase, which is why they look a little long at calipers BUT will be clear of everything so not worried at all.. I also have a couple line locks on the brakes after the master cylinder so if one brakes I can shut off the system to prevent any more fluid leaking out while I fix it. So now those are done and welded so I can clean that housing up to get it painted. Then in a couple weeks I will take that AND the front diff to my gear guy to get them done so I can reassemble those under the truck. Also got some primer on the backhalf, I will have to grind the spots where I weld on the dzus tabs to make the paneling removable, AND i will have to mount my floor jack and batteries, as well as bedside mounts too.
