1992 Ranger Extra Cab - Prerunner 2wd 4.0 V6 Automatic Trans
mgobaja
Jan 2, 2011
107
1992 Ranger Extra Cab 4.0 V6 - Automatic 2WD.
113k miles.
Perry McNeil front suspension, dual Bilsteins, with adjustable coil buckets, using F-150 springs.
Trussed 9" rear end with Detroit Locker, 31 spline axles, 4.56 R&P and Lincoln Versaille disc brakes. National Spring leafs.
King Rear shocks on bed mounted hoop.
Rear bed rack will carry 2 - 39" tires securely, plus the spare for the truck.
Bronco II fuel tank mounted between the rear frame rails - 22 gallon capacity.
3 full size seats, Fronts are in great shape, Mastercraft RS - Reclining, with rear of seat pouches.
Rear is non-reclining Hezco. Perfect legroom for a smaller person ( under 5' )
AC works great.
Transmission was serviced about 20k miles ago, also has shift kit.
AGM Gold Battery is 18 months old
Alpine Stereo - CD and Satellite tuner
Master Cylinder is approximately 18 months old
Rear Calipers are approximately 3 years old
Baja Designs 20" Onyx light bar, as well as 2 Baja Designs XL80 Pro- Racer serise spot lights.
Kenwood VHF Radio, 2 hard wired antennas, run under the headliner to the center console.
Maxtrax - mounted in bed
2- Risk Racing fuel cans - giving you another 6 gallons of capacity
1.5 ton harbor freight aluminum jack with skid plate
Newer BFG All-Terrain Tires 33x10.5x15 - 4 on truck have less than 250 miles on them. 2 more spares on matching wheels, one is almost new, the other is at about 75% of its tread.
Yes this truck will pass California Smog Inspection
Lots of spare parts - tie rods , drive line ( both sections ), ignition control module , spark plug wires , fuel filter , oil filter , air filter, engine oil cap, master cylinder caps, front wheel bearings, serpentine belts, alternator ( new )
The windshield is cracked - I have it replaced a few times, they are under $150 installed.
It could use a paint job if you are worried about it being pretty.
The parking brake does not work, cables are missing.
The dash brake warning light also stays lit ( the ABS module started leaking in a casting flaw, and was removed, but with the locker it never worked anyways ) when that was removed it left an open electrical plug, thus causing the light to stay on.
This truck has been super reliable and I have never hesitated to jump in it to go prerun in Baja, Barstow, Parker.
This is not a fire sale. $8000 - Located in Yucaipa - email at mgobaja@roadrunner.com
IMG_1233.JPGIMG_1234.JPGIMG_1235.JPGIMG_1236.JPGIMG_1237.JPGIMG_1238.JPGIMG_1239.JPGIMG_1240.JPGIMG_1241.JPGIMG_1242.JPGIMG_1243.JPGIMG_1244.JPGIMG_1245.JPGIMG_1246.JPGIMG_1247.JPGIMG_1248.JPG
