- Jul 13, 2014
- 891
- 117
- 43
Forgot to post in here the last few days
Ended up getting the steering set up sometime last week
All clearing what it should clear for the most part
Got the beams pretty close to where they need to be so started on the firewall
Motor is offset a bit to the passenger side so one side is a little tighter but not too bad
Firewall x structure was constructed of 1.75 .120 4130
After laying out the firewall tubes I had a pretty good idea of how I wanted to lay out the tunnel.
Good clearance on everything. Headers will be pretty strait foreword and motor should be pretty easy to pull still.
Time to weld it all up
Some pictures after welding. I hate using the anti splatter spray because it discolors the tube but for some reason the settings I like to use produce a little bit of splatter.
