1993 f150 prerunner
Triphytrucks1
396
1993 f150 5.0 motor with headers and exhaust most of the smog stuffed removed from the motor so it doesn’t pass smog anymore it’s registered until next year. I do know a smog guy if needed Built tranny with a shift kit. Has equal length beams with dual swing steer, 2.5x16 bilstein coilivers and fox 2.0x4 bump stops. The rear is is a spring over leaf pack with extended shackles and Rear end is a 9” with a strange third member and a limited slip. Truck is caged front to rear with 1 3/4.120 wall. Has a 45 gal fuel cell. 2 front seats are kinda torn up center one is still good all have 5 point harnesses. If you have any question let me know might be missing some stuff. The truck has a lot of potential just don’t use it enough
