1996 Ford Bronco Prerunner
Klever
610
9
1996 Ford Bronco. 5.8L windsor, E4OD, manual transfer case, clean title, built by Solo Motorsports. Has original, 93,000 miles, Solo Motorsports stage 5 Kit, 4.5" over TTB, 4.88 gears with Detroit True-Trac, King shocks 18" Front, 20" Rear with Deaver Q80s, 6 Brand new 37" BFG tires, Howe ram assist Solo Motorsports swing-steering with 1650 psi pump, Solo motorsports cage with added tubes, rear shocks inside, 360 welded, connected to the frame, solid body mounts, Currie 40-spline full-floater 4.88 with a spool and Wilwood brakes, amazing center console with Lowrance GPS, Dual fires suppression, gauges, dual race radios, Rugged radios Bluetooth and 3 carbon headsets, all black cotton-braided line (not Push-Lock hose), MasterCraft Seats/Harnesses, Rigid LEDs all over rack and inside cab, Dual Aquas Foam Fire Suppression System, drift brake handle, proportioning valve, line lock, dual batteries, oil containers, (2) 110 watt radios, Art Carr shifter, jack with skid, spare, power inverter, back and forward cameras with recording, professionally wired, all new, never been in dirt. Cleanest thing Bronco you'll see. It has it all, have $89k in receipts. Asking: $44k Text: 951-760-3423
Klever
610
9
Will only let me post 2 pics, says the others are too large. Text for more.
