1st Gen Tundra Repair/Prep
2,025
1,715
id think either is fine. i had planned to do a spacer on my rear bumps if i went up to 35's to limit up travel/keep tires out of the doors.
Reactions: SByota
5,364
2,049
That would be one hell of a thick spacer on the arm. I would extend with tube like mentioned. Personally I would just bite the bullet, cut it off and re install correctly. But only if it were on my truck. My friends truck would get a tube spacer
SByota
451
304
Or just add a thicker strike pad to the arm
It’s getting a tube spacer. One I painted the lower arms already and the spacer is easier. If it were my own truck, I would cut the cans off and do it right. This not being my truck, getting it not to smash the fuck out of the shock is good enough.
DP_Ranger
1,559
447
dana point
I would revalve the shocks, add a bypass, and ditch those bumps all together. Just my opinion
But with the way your buddy drives it’s probably a better idea to leave them in LOL
SByota
451
304
Thats my “phase 2” plan I’m laying out for him. I need to unfuck it first and get it operational again. He probably needs to save some money too.
sc610
1,081
79
Santa Cruz
How did that arm get such a fat dent with the shock bumping out before the bump?
Also, I think the OD of the bumpstop is a little bit under 2.5", which is is why the slit of the can allows you to pinch it. I think a straight piece of 2.5" as a spacer might slip over the lip of the bump.
Edit: the dent is from the stock rubber bumstop
11,915
2,494
Not even close to right. How ghetto is it to just cut a spacer from some 2.25” tubing to make a spacer to extend the bump can a little. I really don’t want to cut off the old bump cans and redo them.
The previous owner of my tundra did the same thing with the spacers. I took them off and found it was bumping on the shocks so he did that. I guess it works lol
Reactions: sc610 and SByota
