oorracing
For stuck misalignment spacers, i heat them up pretty hot with a handheld torch, and either drop them in a bucket of oil and spray the hell out of them with Penetrant oil. The goal is to get them hot and then when the oil hits it, it causes cooling and sucks the oil into the crevices. Then i use the handle off a spud wrench to hammer it into the end of the misalignment spacer and hammer the spacer put the opposite direction. The taper of the spud wrench bites into the spacers pretty well to hold them.
You can make a spacer no problem for those bump cans. I’ve done it in the past and i add the slit to it and put a couple small beads so the spacer stays on the can. It’s less likely to slip over itself if you do that.
Also for single coilover applications I prefer to run the tall, foam Eibach or King shaft bumps. Those things are miracle workers for sure compared to that stupid rubber pad with a metal washer inside that’s on there now. Ditch those for sure.
Valve the coilover to have .020 stack, double the 3rd smallest shim, and run half .012’s/.010’s on rebound and 250psi. Call it a day
