2.5" maximum valving
9,867
643
The question should be how much valving in a resi out the top shock, diameter is not really a factor.
.015's on comp is the most I would run for a durable consistent set-up. You can run more than that buy cranking up the N2 pressure, but it's still going to cavitate and will eventually cook the oil and start hurting the seals and backing o-ring if your shock has one. How long all this tale depends on how hard you are pushing it. For a mall crawler that gets the occasional sweet jump, go for it. You want to run the B1k or run main at Barstow all day, you need to add another shock........
Now if you have something like the Bilstien ACV valve, you can get way more tricky, but I would not run those in the rear.
382
Yea, top mounted resi is the problem. I would assume you can get more out of a 3" coil over because the reservoir is a larger diameter, right? (more surface area for N2 pressure)
I have run a rate plate with .028 distance in a single 2.5 coil over. That's probably the most "valving" I have run. But it's really just a choke point if you think about it... because it is only really "stiff valving" with high shaft speed events. And like barge said... I was running 330 PSI..... and shit would get hot pretty quick if you were shredding the gnar in Plaster city.
BroDaddy has some doubled up .020's in the stack too.. but also has a small flutter. Also has the King compression adjusters.
Wish I had see through shocks I could video. I'm sure it's cavitation city in there. LOL
5,984
309
kevin can better tell you what we had in the front of my silverado but it was hefty. lots of doubled up 15s. we ended up switching the resi to a 3.0 race series resi cuz they can handle more nitrogen. i think we were loading 300 or 350 psi in there
9,867
643
Well, yes, but it never really works out that way in reality.
Say you went from 2.5's to 3.0's on a Tacoma. You would not be using the same shim stacks as the would be to much. The lighter stacks needed for the large piston would not cavitate as much.......
Now if you move up to a F150 that weights 6500#'s your going to need bigger stacks in those shocks and you cavitation problem is right back.
Also, piston to resi diameter is pretty even ratio regardless of size. Unless you get into Blackhawks.............
oorracing
Jan 15, 2006
10,548
60
Long Beach Ca
A total of 12 shims on compression in a 2.5” King Prerunner series shock with a big king race series resi. 350psi in that sucker and it would rip down sand highway! Which if anyone has been to Club Glam lately, they know that those whoops are pretty big. A compression adjuster woulda helped but it was out of budget, so we put foam shaft bumps on there We poor folk make do with what we got laying around!
382
Yea, makes sense ..... and no kidding...the Blackhawks have HUGE resi's!! Like almost coffee can sized.
382
A total of 12 shims on compression in a 2.5&#8221; King Prerunner series shock with a big king race series resi. 350psi in that sucker and it would rip down sand highway! Which if anyone has been to Club Glam lately, they know that those whoops are pretty big. A compression adjuster woulda helped but it was out of budget, so we put foam shaft bumps on there We poor folk make do with what we got laying around!
12x what though? Doubled up 15's?
only1mikey
Apr 24, 2006
11,979
Simi Valley, CA
Three shims on compression is all you need... well that and a rate plate.
Another way to help cativation is restrict the flow to the resi with a smaller diameter hose or if you have the funds, buy a new resi with an ACV valve or a compression adjuster. Fox compression adjuster with the high/low adjusters works really well. I'd say well enough that you MIGHT be content with only running a single shock.
