2:AM Fabrication's 84 prerunner
382
Am I seeing that photo correctly? Are you using a dual rate separator without a dual rate stop, putting the top into coil bind each kersmash?
Had my rear set up similar for quite a long time. I was using a much longer spring and closer rate to bottom though. Made it single rate for me. But, his will still be dual once that top tender spring is collapsed.
84prerunner
2:AM Fabrication
Feb 7, 2008
21,505
73
Covina CA
Been like that for 3-4yrs....finally failed. I used dual rate stops for 1 trip, it sounded like an air hammer hitting my engine safe when they'd hit and the cool was rubbing them pretty bad do I knew they wouldn't last long....sooo I took them off lol
