2:AM Fabrication's 84 prerunner
Do Dah
258
76
Hard hit. I tried the faster is smoother method on main. Seemed to be working on lower main, made the turn to head up upper main and held it wide open in 3rd. Ejecto bumpstop cuz occurred shortly after. Sky wheelied into the face of one of the big holes and my hood popped up, thought I blew the coilover through the hood but it was just the bump
Next time try 4th wide open!
84prerunner
2:AM Fabrication
Feb 7, 2008
21,669
225
Covina CA
Made more suspension changes today. Added more valving to compression and rebound on the bumpstop.
also got rid of the .060” washer between the shims and rate plate in the piston in the shock. Should make things drastically different.
Do Dah
258
76
What rebound valving are you running in the front shocks?
84prerunner
2:AM Fabrication
Feb 7, 2008
21,669
225
Covina CA
It’s an IBP so it has 2 pistons. Ride height piston is all .015s, bump zone piston is .015s with big 1 or 2 being .018s. I’d have to check my notes.
