2 Door TTB Explorer Build
mjlogan
space cadet
Feb 9, 2007
703
84
ontario ca
Got it up to the desert this weekend. Took dirt up the pass Friday night, camped at the buttes and did around 50 mi of smashing around Lucerne and Barstow. Explorer ran great the whole time.
Ended up with a good group of solid trucks, one hood was up for about 5 min fixing a loose ground other than that just ripped the whole time
Ford commercial circa 1990
And of course
Impressions:
-Rear end ate everything up despite the shock angle that "will never work" Maybe a little less rebound though I didn't bother turning tubes.
-Front end is soft on compression, maybe needs a little less rebound as well. Worked good if i had the balls to keep my foot in it or where it could pop over holes.
1,115
Impressive! I think this is where we all should take note. You are out in the desert enjoying the hell out of this thing already!!! No 3 yr multi billion dollar build. I mean how long from day 1 till the dirt!?
Good job, and way to set an awesome example for others to see. This is what it's about.
mjlogan
space cadet
Feb 9, 2007
703
84
ontario ca
Thanks! Glad to see you get what I'm after
I took it apart July 4th of this year but really didn't start hitting it heavy until the first weekend of September. So 4 months give or take which is longer than I had originally hoped.
As soon as I pulled the beams off my brother came home with a big ol turbo and an LS engine for his Pontiac, so I got a little side tracked for a month or so.
Everyone that sees it says broooo what a sleeper! Siiiiick!! I didn't intend for it to be a sleeper, aftermarket wheels cost money and tube bumpers take time to build. If sleeper means lazy then yep got that right!
4,217
3,284
mjlogan is a budget build missionary. Spreading the word of truck usage far and wide with his message of reduced build times and realistic project costs. I will strive to adhere to your teachings, oh enlightened reverend of truck completion.
mjlogan
space cadet
Feb 9, 2007
703
84
ontario ca
Working on a mini bumper idea to finally get my swap meet hella 4000's mounted. While the $5 amazon lights work suprisingly good they are getting a little rattly and hard to adjust.
Grabbed some scrap tube out of the pile and mocked this up. Will bolt to stock bumper mounts, go through the opening in the bumper, and tie into the typical steering protector hoop below the frame.
Also picked up a TIG welder and damn am I out of practice. Bolt on flags for the front mounting points on the bumper. Fit the caps up like I was gonna MIG them haha.
runners_pre
613
7
Rialto, Ca
Dam I just realized that your the dude I met at your shop in Colton, I remember checking out the white ranger and you had a bunch of Baja bikes. I picked up a Mazda Navajo 2 dr for 300$ running and I have about 4500$ into mine. I’ll be picking your ear a lot I’m sure haha
Reactions: mjlogan
