2 Piece Drive Shaft and 4 Link
socalkid92
2,541
49
National City, CA
What is the optimum location for a 2 piece driveshaft to connect at the 2 u joints in the center on a 4 link setup? Is it at the same pivot point as the lower link? Upper link?
I have a 4.0 with a c4 trans on an extended cab ranger.
I have a drive shaft that was given to me by a friend where the u joint is at approximately the same point as the upper link pivot point off the frame. I can possibly get it shortened if needed.
I still haven’t built a crossmember for the carrier bearing either so that can be put anywhere.
11,969
3,365
Driveshaft should be about the same length as the lower links. The u-joint will be in front of the arm pivots. Vertical placement is also a little tricky to manage plunge.
Reactions: Big Ron Dog
socalkid92
2,541
49
National City, CA
Cool that sounds good! Do you know where I could get a good carrier bearing that will hold up to abuse?
84prerunner
2:AM Fabrication
Feb 7, 2008
21,673
230
Covina CA
Best bet is to run a fixed yoke at the trans and a regular rubber type bearing. A fixed yoke eliminates most of the force that kills the bearings. If you have to run a floating bearing a solid bearing like barge posted is the best bet, that’s what I run, but you do get more vibration in the cab.
socalkid92
2,541
49
National City, CA
Cool the trans actually already has a fixed yoke, supposedly it’s built with billet internals and all the goodies but I never opened it to check.
Reactions: partybarge_pilot
6,404
910
A fixed yoke saved carrier bearings. I run a rubber cased bearing and it’s been 3 years with 0 issues
Reactions: socalkid92
