2002 Chevy Silverado
andrewzermeno
Mar 4, 2017
45
5
Madera,CA
So started a build for a friend.
2002 chevy silverado 5.3 single cab
currently has the cateye swap on the front
TO DO LIST
t.e. designs shock towers(wiy)
boneyard fab 4.5 ext per side kit(uppers,lowers,spindles)
kings on all fours(front 2.5x10 coilovers)(rear 3.0x16 triple bypass)
front is also getting camburg hubs
37x12.5r17 toyo r/t with mickey thompson beadlooks
bedcage,bumpers,engine cage,harness bar for prp harnesses
needs front mcneil glass installed
rear fiberwerx 4.5 bedsides going on
rear plated bumper
deaver u182 for the rear
dirtbfabwerx shackle and hangars
few other things etc etc...
andrewzermeno
Mar 4, 2017
45
5
Madera,CA
tearing down the front to clean up the frame and start mocking up the kit
Boneyard Fab 4.5 over kit
spindles, uppers,lowers
dirtking alignment cams
heim steering
t.e. designs wiy towers
camburg hubs
truck is also getting 1/8 frame overlays so that's why the frame is cleaned up on some pictures
andrewzermeno
Mar 4, 2017
45
5
Madera,CA
Progress so far...
Bedcage 80% done
Bumper 90% done
rear bumper 80% done
front still needs frame overlays
to be cleaned up and the towers to be welded
engine crossmember is going to be 1/8 all boxed structure(maybe add some dimples)
rear needs shackle hangers added and deavers
going to cycle the rear once thats all installed by removing leafs and just leaving the main
straps and bumpstops are going to be added I forgot to mention
Front is getting 3.0 king bumpstops
Rear 2.5 fox bumpstops
the rear is also going to be c-nothced
rear frame rails from the rear cab back is going to get plated
truck currently sits on 37s
Reactions: mikey09120
6,291
719
those u 182 springs dont really allow for a notch. on my old truck they were a little negative when the axle met the frame without a notch
Reactions: andrewzermeno
andrewzermeno
Mar 4, 2017
45
5
Madera,CA
How did you determine the rear shock location without the springs, hangers, and shackles? The last Silverado I built with U182 and Mazzulla parts ended up with the upper shock mounts well above the bed, granted the lower shock mounts were on top of the springs.
The bedcage isn't final it's off only by 1-2 inches either to be pushed forward or backward. Everything was measured and the shock mounts are coming off the axle at a 45 degree so facing downward right now to allow the bedcage to sit below the bedline to keep it clean. It's going to get strapped and bumps all put in place also.
Last truck I had with U182 and a 16 stroke shock with the lower mounts on top of the leafs put me 4" over the bedline.
Reactions: MullenFabworks
