2002 F150 9.75 rear end, 488's, ranger pattern
HotRod82
Aug 10, 2009
31
As the title says - Ford 9.75 rear end out of a 2002 F150 for sale. Axles drilled for ranger / explorer 5 on 4.5 lug pattern. 488 gears with the factory ford posi. Big disc brakes. Still has VSS so your anti lock will still work. No truss, but the tubes are tig welded to the center section. I had this unit under my explorer and it works great. Spring pads and shock mounts are currently set up for a Giant link killer SUA mounted outside the explorer frame rails. 66" WMS, and I have a set of wheel spacers if you want them. $400.00 OBO. 6 1 nine- 8 5 5 2 2 1 zero. I'm in san diego.
