2002 f150 steering column help
Triphytrucks1
413
2
so I'm ditching my stock column but keeping my stock steering box, im trying to figure out what ujoint I need to connect to the Ford factory box.. or how people have used aftermarket steering columns for these trucks! Please help ūüôŹ
Reactions: ljubera0250
ljubera0250
3,819
700
Hemet, CA
www.instagram.com
You're going to have to build an adapter to go to the stock column. Best bet would be to pull your box off and take it down to Kartek (or measure the O.D. and count the splines). The factory column has an aluminum u-joint on it from what I remember, you'll have to cut the factory shaft that goes into that aluminum u-joint and weld that to your new shaft. I hope that makes sense.
Sent from my LM-V405 using Tapatalk
Reactions: Triphytrucks1
