2004 toyota aisin a340e 2wd transmission and 8.4 third member with 4.56 and trd limited slip
362
78
Swapped my 2wd transmission for a 4wd with transfer case. This trans is originallly out of an 04 2wd Tundra has approximately 275k miles on it, fluid was clean and shifted well before removing. Trans was installed 3? Years ago with new filter and fluid. Will ship.
Asking $300 plus shipping obo. Includes torque converter. I have both an abs and non abs tailshaft housing and speed sensor.
I also have a spare blown 2001 a340e that this trans replaced that I dont have a use for
362
78
Trd kazuma limited slip with 4.56 gears, make an offer. One of the ring gear bolts backed out and put a slight groove in the case. All ring gear bolts were replaced with new oem toyota bolts, torqued to spec with loctite. The gears, carrier and case all looked okay with the exception of the groove on the cap.
Make an offer, I need the space.
362
78
Considering selling my deaver g57 soa springs. They were recently disassembled, cleaned, greased, and reassembled with new pads and bushings.
Make an offer
