2006 Toyota Tundra ABS early activation
armrunner
2,455
2
Hey dudes. Changed ring and pinion out today and after install i notice at very low speeds while applying the brake it seems abs is kicking and pushing back at me while stomping on the brake. Brakes work fine at higher speeds. 5mph or slower it seems to go wacko. Any of you Tundra guys have a fix for this? All i see on the web is talk about that actual sensors being dirty or bad but they worked fine before? Thanks for any info!!!!
-Brent
armrunner
2,455
2
Bump...i know someone out there has had this issue!!!!
304
49
I can offer no input, my 01 is a non abs. What year is the truck and is it 2wd or 4wd? When you did the gears did you pull the axles from the 4 bolts on the housing or leave the flange bolted up and pull then from the end?
sc610
1,024
7
Santa Cruz
The sensors come out with one bolt. Have you checked them to see if they are dirty?
Was proportioning valve messed with at all? Were your brakes bled properly?
Sent from my SM-G892U using Tapatalk
armrunner
2,455
2
Ive checked the sensors. I dont think wether the brakes being bled right or not would affect this. If i had spongey brakes or if i had to pump them up here and there then i would have tried to bleed again. This is just abs freaking out and engaging. I have found one other person with the exact truck with same gears and has same exact issue.
