4 Door Mini Me
10,583
1,792
After my hand made my crow 5 points release causing me to be ejected and almost dying I would highly suggest some good harnesses. I just bought a new set of PRP and even if you buy used make sure the latch has the little velcro strap on it. Mine did not and after the accident I sat in the truck and swung my hand one time and it released. The back seats had it and I did it probably 20 times and it never released.
12,377
3,136
Yeah I plan on getting the PRP 5.3s. The sternum strap is also super important for me. My strikingly large (aka short and skinny) stature makes it easy to slide out of belts.
Reactions: 85yota
12,377
3,136
Not much to post on the truck. Got the harnesses from Canks and picked up a bench for the back. Pulled out the stock rear seat yesterday and got them sitting there. The seat will be raised up when the cage is put in. I should be able to cut the floor out for the back passengers and make a new floor lower down for more leg room.
12,377
3,136
Looks like a nice fit
Yeah should work out perfect. The gas tank is actually pushed into the back of the bottom cab corner about 4 or 6", so the seat cant go back more. Not a huge deal, since I'll be reclining the seat a bit and it needs some space away from the rear firewall for tubes to fit
Reactions: bullnerd
12,377
3,136
Links? Yes.
Backhalf? Not entirely? Might chop the frame rails at the back and replace with rectangle tube to narrow it up a bit for room for shahks. Still going to have the bed, though. Still undecided if I'll do a full bed or keep the mini bed
2,423
2,324
Links? Yes.
whats the current wheel base?
