4 Door Mini Me
12,583
3,467
Lol, the Samurai will have a turning radius of 128".
Short wheelbase doesn't need a steering quickener.
Says a stock bronco will have 150".
So if they are taking this from the centerline of the vehicle, you would need to times the radius by 2 and add the width of the vehicle to get the diameter on the outside. So if yours is 22.5', that would be about 52' circle. Is see many 3 point U-turns in your future. Where as the Samurai! will do it in a 29' circle.
yes, from center of vehicle. That’s how a radius works lol. The spool won’t help anything. Nothing a little skinny pedal can’t fix.
none of what you said matters anyways. The samurai isn’t ever going to drive 🤷🏻‍♂️
12,583
3,467
On it's own weight for the first time. Got a truck coming back in for a couple weeks so I need the driveway room. Also, went to a hose shop and they're making me a power steering pressure line, so hopefully I can get that on by early next week and stop dumping PS fluid every time I turn the wheels.
PS: Thanks Cole for the fabricated stock steering I pulled out of your dumpster. Works great for this. A bit too short to actually run, though. (Did someone say cut, sleeve, and extend?!)
229574
229575
229576
