4 link set up help.
ratboy93
703
alta loma
I have some 60 inch links that i modify down to 55inch that put the coilover only 24inch from the rear heim.
How long from center of axle to the cab is it when you shorten the truck up to where you want it?
roughly 34" stock so that would be 27". so with that that will leave 7" from the cab to the tire on 40"s
ratboy93
703
alta loma
these are all rough measurements as i havent got the truck in the shop yet to get the rear end torn apart and mocked the new rear end at different wheel bases. just trying to get a head start on some homework.
ratboy93
703
alta loma
140" is still pretty long. Just bite the bullet and cut out the back of the cab for the shocks. Then set your wheel base down to where you want it.
Like this.
this is what my thoughs were to start. just bring the shocks in the cab and box the cab around them with an inspection plate. also want to keep my rear does usable as in someone can get in and out of the truck through the rear doors. also i would like to keep the bypasses as close to out of the cab as possible as im sure it would be super pain in the butt to tune the bypasses when they are buried
goofballracer
whatever
Feb 8, 2008
3,049
54
We are all about the up travel at our shop. I tried to shorten my truck up a little over where it was at and the head of the coil overs are halfway in the cab. With 40"s ground clearance should be an issue I have at least 6" maybe more.
ratboy93
703
alta loma
i usually setup the trucks so full bump the top of tire is 1" from top of bedside.
goofball what did your wheelbase end up as? i too like that up travel and a low ride height.
85yota yea that makes sense for sure.
i wonder how much rollout the 40" tires produce. now a 40" on 17" wheel has a lot of tire so i doubt it will play a major factor.
9,855
635
i get it. i know the shocks are going to have to work a lot harder and the travel numbers will change. im also content with mid 20's.
Actually the motion ratio will be lower making life easier on the shocks. Problem then is light springs and getting enough low speed damping out of them to ride nice.
ratboy93
703
alta loma
yea i was apparently thinking of the shocks being way more towards the front. idk ive been searching and reading all this link stuff my brain is probably gonna explode. i get a little obsessive sometimes and want answers. trucks are dumb.
