1,211
608
Also, if you make the rad fill from the bottom and pull from the top, you can starve the pump unless it’s completely topped off with water. My sand car came that way and temps were all over the place. Swapped hoses around and muuuuuch better
Reactions: dose
dose
Jan 4, 2018
209
348
Mammoth Lakes CA
Thanks for the reply’s. I posted this question on glamis sandrail forum too because there are more Subaru guys there. They said it wouldn’t work and the water pump would cavitate so I guess I will plumb it the hard way.
dose
Jan 4, 2018
209
348
Mammoth Lakes CA
Some more pictures of the vw-Subaru conversion.
I plumbed the radiator with the stock flow path routing is why the hoses do a weird criss cross when they exit the beam.
Radiator is mounted
I will be adding some sort of air intake or holes or mesh to get some air under the hood.
4,128
534
You really need to glass in one of those grilles from a knock off manx. HA. Or find one of those bug grille conversion things:
A wild fiberglass mating of a C-cab rear to a toad dune buggy ...
Spectre BGW Ltd. - Body Components Customs Hoods/Bonnets and Grills
  • Haha
Reactions: SoupGFX and dose
dose
Jan 4, 2018
209
348
Mammoth Lakes CA
The Baja is running good and is a blast to drive with the horsepower doubled. I will probably Leave it how it is this year so I can start focusing on my chinook.
I added another leaf to the rear packs since last time we used it it had way too much Cali lean going on with a trailer.
Hoping to get the paint and body work done this year and some interior. Needs basically everything inside including replacing the floor.
