dose
Jan 4, 2018
278
494
Mammoth Lakes CA
What length lower links are you running? I am considering a set of 48" lowers for my tundra to try and keep as much of the bed as possible.
49” lowers, 40” uppers
Good luck keeping a bed on linked truck. After you cut the wheel wells for up travel, Cut the front for the bypass and coil overs, cut out for your fuel cell and upper link clearance at bump and poke holes everywhere for cage there’s won’t be much left.
Reactions: smokeysevin
dose
Jan 4, 2018
278
494
Mammoth Lakes CA
Got the stuff from stock gas tank transferred to the 22 gallon fuel cell.
Filler, vent, return, fuel pump and gas gauge sender.
Got the tacoma e-brake cable modded to the T100 rear.
Pretty stoked how it came out pretty clean and the cables don't touch frame until the last 3/4" of bump.
Plan on doing the brake lines tomorrow.
dose
Jan 4, 2018
278
494
Mammoth Lakes CA
Got a bunch done this week
Cab cage mostly done. Need more metal and still need to put a X by back window and paint but pretty happy with how tight it came out. Pretty basic cage compared to a lot of stuff I've seen here.
Rear cage done and painted.
Shock mounts done.
Bump stops handled.
fuel cell wired and plumbed.
battery mounted
