4x4 dbl cab tacoma build
jonsangel
1,444
472
Los Angeles
I know I've cycled it but I cant find pics for the life of me. The headers are about .25" from the frame. They hug pretty close. The tires don't really get that close them since they are sticking pretty far out. I'll snap some pics when I cycle it next. All my pics are bump and lock in the opposite direction
jonsangel
1,444
472
Los Angeles
I got a little bit farther on the wiring. It ended up being a lot more complicated than I thought it was going to be. I'm not reusing any of the stock wiring or than the modified wiring harness and probably door wiring.
I'm wondering what the hell I got myself into at this point
226236
The sleeving makes it look so much cleaner
226237
Final wiring leaving the firewall. one loom goes to the front and the other to the rear
226238
Half the dash wiring lands on this fuse panel and the other half goes into the bulkhead connector
226239
The dash is officially in. I just need to land all the wires. I decided to put voltage in the empty gauge spot. I'll make covers for the empty switch holes. I didn't end up needing the ones I had planned to put in there. I'm sure I'll need it for something.
226240
2,014
man, i am NOT looking forward to wiring...
and just put some switches in there... you'll find a use like you said.... rock lights, whip, or something
889
547
That switch is different than the one on my a340 shifter. I wonder why they used a different switch type since the shifters are so similar.
jonsangel
1,444
472
Los Angeles
My recommendation is to drawing everything out before you start. include color and line amperage. Yours should be a little easier with the switch pros. I also regret doing the panel fuses on the dash. It makes sense for a race truck but not for a play truck. At least it looks cool
Are they still contact switches?
DirtFiend602
DR Maitre'D
Dec 12, 2008
15,599
3,096
Tinycad is a great free program for making Schematics and line drawings, with symbols and all.
