4x4 dbl cab tacoma build
Jester9
The Jester's Workshop
Apr 1, 2014
874
794
Central Texas
What he said^^^^^ not sure on the exact number but you definitely need a little negative
2,176
I do the toe all ghetto using the tread on tires and a tape measure in my driveway. Make front about 3/16" narrower than rear of tires. I have also tried clamping levels to wheels and using them instead of tread. Same results.... which is... seems to work! hahah
You just reminded me with your paint marks. I need to mark my driveshaft so i know how it was assembled for balance...
jonsangel
1,516
584
Los Angeles
I did 1/4" with the 4' sticks. I think i'll need to go a little more negative. I'll try your method now i have the wheels on.
I also punched an "X" on the fittings for when the paint fades or get's scratched off
2,176
^^^ my plan was to use my auto center punch to mark one side as well...
funny fact... i was paranoid the weight of paint could make shaft less balanced. So my shaft is still raw dog.
That's just stupid talk, right? LOL
jonsangel
1,516
584
Los Angeles
I can't see it being that sensitive to weight. Plus the paint should be pretty even around. Th e driveshaft place painted mine. It was painted after it was balanced though
