4x4 Twin Traction Beam products
Threat Motorsports
Threat Motorsports
Aug 15, 2007
1,887
www.threatmotorsports.com
Threat Motorsports TTB products. Pm me for prices. You get the best price when you buy a complete kit. Please specify what options you would like.
TTB options:
-Standard Cut and turned D-35/D-44/D-28s
-Billet Cut and turn D-35/D-44s
-Extended D-35s up to 5" (more then 5" add $200.00 per inch)
-Extended D-44s up to 4.5" (more then 4.5" add $200.00 per inch)
-3rd member clocking (Beams MUST be built to accommodate clocking to ensure proper axle alignment for spindle/hubs)
-Uniball pivot upgrade
-CNC bent truss/extra plate work
-NEW Custom axles (SORRY!...WE DONT EXTEND STOCK AXLES ANYMORE)
TTB Radius arm options:
-Standard Boxed style Radius arms w/radius arm brackets
-Extra ground clearance race style boxed radius arms w/pivot brackets
Additional components
-Ford Bronco bolt on rear shock mount
-Crossover steering w/2 bolt on swinger brackets, 2 swingers, and 4 tie-rods
-4" coil springs
-Custom Threat/Radflo direct Bolt in shock
-Radflo 3.0 Coilovers
-Radflo 2.5-3.0 Bypass shocks
-Radflo smooth body shocks
-Bilstein 5125 shocks
-Stainless steel Brake lines
SPECIALS!!
C&T beams, Custom radius arms w/brackets, 1 1/4" hiems w/spacers, 4" Autofab Coil springs, Bilstein shocks, Alignment cams, braided steel brake lines, and hardware PM for the lowest price!!
Threat Motorsports
Threat Motorsports
Aug 15, 2007
1,887
What about any steering options for TTB's? Do you offer a crossover steering setup?
I will be releasing our new bolt on dual swinger set up next week for the TTB F-150 2wd unequal length beams, and F-150/ Bronco 4x4 finally! Im just waiting for the swinger plated to come back from waterjet. Im sure my buddy is going to be be happy since I have had is Bronco here for almost a year and I know he is anxious to drive it again haha! Ill post the pics of the brackets up today. I need to clean the rust off them and make them look purdy again.
Edit: There are actually pics on my website in the 4x4 beams section.
partsjosh
Sep 30, 2012
wanting to widen the 95 ranger's d35 ttb. what options do you have to widen them, im trying to fit 35s under a fiberglass one piece
