Do not go down in size on the radiator line. Run as much hard line as possible with the fewest joints. Flow restrictions need to be kept under control with lines that long.
Dangit, ok. it worked fine on my Bug but i guess this is flowing a bit more.Do not go down in size on the radiator line. Run as much hard line as possible with the fewest joints. Flow restrictions need to be kept under control with lines that long.
I actually dont have that hat anymore. I switched it to the holley one. But I really dont think any "hat" is going to be ideal with a 4 barrel TBI.That shitty little carb hat is causing your fuel distribution issues. But I think I mentioned that way earlier..........
My merge is actually the intercooler so hopefully I wont have any issues there. inlets come into the outside bottom of the intercooler and collect in the top plenum. the top plenum has a pretty big volume and should mix the air well right before it goes into the throttle body. What do you think? it probably not optimal but thats about the best I could come up with for packaging.Long ago I had a blow through set-up on a Mustang. It was a Paxton with the carb in a box deal. Granted, it was only running 7PSI, but it didn't have any of the issues you are describing. Why? The box was large enough that it didn't effect the airflow around the top of the carb. FWIW, I have had the same issues on NA motors with those stupid little hats and UMP's. The only ones that ever worked were at least 10" in dia and designed so that the inlet flow didn't fuck with the carb.
The new set-up will solve those but you need to pay attention to the merge for the inlet pipes. Get it wrong and it will also give you fit's.
