- Jan 31, 2005
- 5,158
- 1,732
- 113
Welcome to the club...
I run the TC caddy kit, TC steering and Fox coilover (lower uniball and Fox bypass sitting on the work bench waiting). Got the entire kit with front and rear 4.56 gears for a deal I could not pass up.
Had Deaver make a custom set of F67 with a little more arch and I believe a leaf or 2 extra for the weight of the rear of a 4runner.
I really wanted the JD race kit making it 2wd. Friend runs that on his 4runner and it is awesome.
For the rear window... There could be a couple reasons. The gear strips. Pull the interior panel. Pull the regulator. Find the stripped gears. Make teeth by welding and then grinding into shape. I did this when I first got mine and it has been great for over 10yrs now. The shell needs to have the 2nd bolt from the rear on the driver side installed (with the correct length bolt) or it will not work. There is a micro switch or something on that bolt.
If you ever have starting issues let me know... There is a hack to fix it. Acts like it needs starter contacts but even with a new contacts or a new starter it did it. Found the fix and has been great for years also.
I agree... Run a coilover for now and then add the bypass when you can afford or find used or if you even need it. I have been coilover only for years and years.
