89 Ranger 4x4
GahnRacing
Bonsai Trimmer
Oct 5, 2012
431
132
Clovis, CA
Figured I'd post a little bit of an update. I've almost completed the fuel cell mount and now I'm moving onto my links. The swaybar is in its final position just needs finishing touches and mounts for the rear end
mounty71
2,710
San Francisco
Those links look good! Why did you mount your links directly off the front of the axle as opposed to below it? I assume you haven't noticed any ill effects from it.
GahnRacing
Bonsai Trimmer
Oct 5, 2012
431
132
Clovis, CA
Thanks man, lots of hours lol. I bought the rear end already tabbed. I'm not sure of the exact benefits of ethier but I do get a little ground clearance with this setup
313
Digging the links!!! Makes me want to try making some myself
What size tube and thickness? Any internal ribbing? Or just the side and top plates?
GahnRacing
Bonsai Trimmer
Oct 5, 2012
431
132
Clovis, CA
Digging the links!!! Makes me want to try making some myselfWhat size tube and thickness? Any internal ribbing? Or just the side and top plates?
Thanks, 1.75" .120 wall DOM, 2" .250 wall DOM front bushing pivot, .125 cold finish plate, 1.5 x 3/16ths cold finish flat bar, internal ribs between shock pivots and 3 internal ribs at 45 degrees in front of front shock pivot
313
So, the taller side plates and overlays are only 1/8" cold rolled?
Top plate is 3/16" I assume the internal ribs are 3/16" too.
(I thought the taller side plates underneath the overlay looked like 3/16 ... like the top plate? Eyes must be failing me)
