94 Explorer
1,869
621
When I built my d44 explorer i through the rear axle that was in the bronco I got the beams from. The wider axle made it very easy to mount shocks outside the frame. That said I jut ran 2.0x10 Fox’s in “stock” location, with deaver g50e’s. I ran stock location lowers and built an upper mount that leaned back enough to fit, wasn’t ideal but it worked.
Also, did you do the work on the beams? If so you could probably link it yourself with files from diy. You’d have to run a funky 3 link to clear the tank, or pickup a bronco tank (or similar) to put behind the axle.
