94 Ranger Build
AshtonP59
94 Ranger Prerunner Project
Feb 18, 2019
65
21
Oak Hills, CA
So I've been lingering here for quite a while and I figured I might as well make one of these threads for my project truck. I don't have very many build pics because I never think to stop and take pictures so I'll just post what I have of it in it's current state and give a brief explanation.
What it came with/what I have so far:
Front:
4.0 w/ Manual Trans
Extended D44 TTB beams and the rest of the front is D44 as well.
Drilling out to 5/8 studs
It had 12” Coilovers on the front but I’m putting 14s on it (still need some hmu)
Engine Cage
Need an intake
Camburg Radius Arms
Custom metal dash (ugly im changing it eventually)
Got some MasterCraft seats for it
It has Mustang padding lol
Flomaster muffler and custom headers
Rear:
Giant 64 leafs with big shackles
Got a 28 gallon cell for it
I have 6 Ultra X103 15” wheels
I have 3 Yokohama 35s (need more)
Ford 9 inch rearend
RuffStuff truss kit, disc brake kit, and making shock mounts for the 9”
9” has 4.56 gears with a spool
Got King 3.0 16” bypasses
Should get around 18” of travel
C-Notched the frame
Cage is all mild steel unfortunately but most of the work I’m doing to it will be chromoly
Edit: turns out cage is dom so that's nice
I will post some of the pics I haven’t got many though. Planning on cutting it behind the notch and sloping it back and having one spare up top and fuel cell below. I will update as I work on it!
214342
x
The photo attached is me when I picked it up. I am almost 14 so it will be a project truck for when I get my liscense.
AshtonP59
Feb 18, 2019
65
21
Oak Hills, CA
214344
Full-ish droop after I washed it. It came with a rusted out front diff, and apparently the transfer case electronic motor is broken so no 4wd for now. Maybe down the road.
AshtonP59
Feb 18, 2019
65
21
Oak Hills, CA
214345
214346
214347
Previous owner crashed into a ditch, broke one of the beam mounts off, got it back home and parked it for 5 years, then I got it.
AshtonP59
Feb 18, 2019
65
21
Oak Hills, CA
214361
Cut the shock mounts off. Making new ones using a tube from the red mark to the flat tube under it, then putting a boss in the middle. Also bringing a tube out to capture the outside of the bold so it’s not a single shear death sentence.
