95 F150 prerunner
Tdiesel18
Nov 26, 2017
27
Truck is just about done. Figured I'd share what's been going on over the last few months even though I'm on the fence about selling it now. If there is any interest though feel free.
Truck:
95' F150 with 5.0/E40d. Motor has 65K miles and trans has 500 post rebuild. Fully caged bumper to bumper with 2" DOM, suspension and shock mounts chromoly.
New parts list:
1.75" king pin beams w/ radius arms, swing set steering, all double sheered an all brackets/hardware .
Proam rear housing, 40 spline axles, 9" 3rd member full spool 5.14 gear ratio
60" trailing arms
New sway bar & sway bar arms
Proam front/rear hubs 6x6.5 lug pattern
Wilwood 6 piston calipers with rotors
King 4.0x18 6 tube bypass
King 3.5x16" 5 tube bypass
King 4.0x2.5" bump stop
(6) vision beadlocks
(6) BFG KR3 40"
55 gallon fuel safe cell
PRP Alpha wide seats
McNeil one piece front clip
Mcneil bed sides
New break pedal assembly and cyliner
Break line
Fuel lines
Adjustable steering column
Quick disconnect/ w new steering wheel.
Tdiesel18
Nov 26, 2017
27
who did the cage and who made the steering/beams/links?
where are you located? any idea of a price range?
Cage was done by Jorman Raceworks prior to me buying the truck.
All fab work post me buying the truck has been with MMW (Moores Metal Work).
Front end is a kit from MMW.
Links were cut by a buddy at performance water jet and welded up by MMW.
New shock mounts & good amount of rear back half was redone as well.
Located in San Diego or Lake Havasu.
With what I have in parts & labor at this point would be searching for $65k-70K. This would get me breaking even on just the parts and labor.
4,443
869
Knew Matt long ago. Got in some trouble together. Drove his dads golfcarts around VC and had a good ole time. Ah the good ole days.
