97 f250 7.3 coilover springrates and valving
What springrates and valving would you guys recommend with a 16" 2.5 coilover on front of an 97 f250 2wd unequal length beam setup? For on road daily aswell as offroad daily ..im running 450 over 700 with unkown valving atm and id like to switch it up truck is long box extended cab
96f-u250
841
112
VenTurA 805!
I had about the same setup but with a 4.9L .. I had a triple rate kit with 350/600 for a lower ride height.. this was my [FONT=.SFUIText]coilover valving 160psi[/FONT]
[FONT=.SF UI Text][FONT=.SFUIText] Comp. -- Reb.[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]1.7-- .015 .015[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]1.6-- .015 .015[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]1.5-- .015 .015[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]1.375-- .015 .015[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]1.25-- .020 .015[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]1.125-- .020 .015[/FONT][/FONT]
mine was setup on the stiffer side for jumping though.. Its gonnna depend on your beam weight,leverage and shock angle.
