97+ Ford Beams?
Nodakfords
Jul 11, 2020
1
Bismarck ND
I’ve looked through everything I could but I can’t find if the 97+ F150/250 E250/350 Beams with the ball joint are cast or forged or worth messing with.
A good example is a 99 E250 that I cam across. Are these beams a viable option for modifying?
If these later 80s+ ball joint beams are a no go for modifying them what year spindles can I get front steer on the 70s forged beams?
Jester9
The Jester's Workshop
Apr 1, 2014
530
283
Central Texas
If you want to modify beams they need to be forged which also means pre 1990ish
littlebird
Feb 26, 2019
50
68
NY
All F-series beams were cast after ~1986 if memory serves, except for the big mono-beam under the F450's into the 90's.
