Lookin good bud. Is that landing pad big enough? I can see the bump sliding off it while articulating. I've seen it happen and the axle got stuck like that because the bump got caught on the lip of the pad
Thank you! They worked before being 1.75” tube and it only took a little bit of the back part of the delrin off the bumpstop striker. Hopefully what I added will help and be enough. In retrospect I should have bumped off the axle tube and made a larger bump pad. I think it would have helped prevent my axle tubes from bowing as well.
My bumps scrub a 2” (fore-aft) by 3” (left right) area on my bumpstrike pads.
Leaf springs allow the axle to move around quite a bit.
dam thats a big striking area, I have 2” stroke bumps, are yours longer?
