97 Hot Roll Ranger
96f-u250
801
49
VenTurA 805!
Seems like a good baseline, what about n2 psi? Also, do you recommend starting with tubes open or closed for a baseline and is there a better way to tell differences in tube adjustments from starting all open or all closed?
garrettw
Mar 23, 2015
106
San Clemente, CA
Pretty sure I read somewhere to start with them open and close them for desired performance but don’t quote me on that..
96f-u250
801
49
VenTurA 805!
Sorry, im gonna quote ya, alrite I think ive done that in the past Id rather start soft and then end hard... actually the other way sounds better, never go home hard i heard. And care to explain what that is you’re making?
96f-u250
801
49
VenTurA 805!
Well ill be working on lower bypass mounts tomorrow.. slightly digressive C/O.. oh well the bypass should be progressive and be able to make up for that.. Im at around 20” travel with 13.5” out of the 14” C/O.. any rough estimates for camber or caster angles I should not exceed when I am Limiting travel? Or other things to consider? Thanks..
garrettw
Mar 23, 2015
106
San Clemente, CA
Sounds like you knew the answer to your question. And spanner and knock out for the lower seal, also fucked up a perfectly good pair of needle nose because I couldn’t find my big snap ring pliers hah
