98 4x4 Tacoma
dalandser
Sep 30, 2017
40
10
Build in progress
So Far:
New engine & trans
Solo XLT front kit minus axles
ARB front locker w/ 4.56 gears (ECGS)
TRD SC
New doors, fenders
To Do:
Deaver e30's w/ 12" bypasses or cantilever
Front shock hoops w/ 10" co's & bypasses & 2" bumps and front axles
2nd Gen Tacoma rear axle w/ 4.56 gears & air locker
Rear glass
Bumpers & winch
other stuff :)
Thanks for looking
Bought 1/17
Current:
dalandser
Sep 30, 2017
40
10
Some friends are helping me make some shock hoops to get 10" shocks installed and get my ride height right. It's a slow process with the friend with the bender 30 minutes away, but for just the price of gas and a few Mt. Dews as payment it's definitely worth it when compared to buying a bender for like 2-3 bends.
Now fitting tabs to make the bypass fit under the brake booster is what seems to be the toughest challenge. Seen a few similar builds my friends and I are getting ideas from.
dalandser
Sep 30, 2017
40
10
A friend helped weld in some double shears, no more coil buckets :)
Getting alignment in spec prior to going further with the shock hoops
Checking for bumpsteer
dalandser
Sep 30, 2017
40
10
Been awhile since making any updates - around January I got the truck turned around. First time I drove it at all in 1.5 years.
Immediately started removing the bed and cleaning off the spring hangers.
Got rid of the stock width e-locker.
Got a 1st Gen Tundra axle as a temporaryish rear axle.
Got bedsides installed
Anthony helped me weld on new spring hangers. We cycled the suspension.
Put the pack together and put the truck back on its own weight about March.
Had a high idle that wasn't immediately obvious to pin down and I had bubbles in the coolant beyond where I thought I would have them while purging the coolant system. Checked a bypass tube that can sometimes hide a coolant leak, but it was drier than a popcorn fart!
I opened up the intake and looked inside which turned into an all nighter as I rebuilt my donor throttle body and added better hardware while I was at it just to rule out a faulty IAC as its cause.
Still need to fab up some bedside braces. Bought a Trail Gear bumper and modded to my liking.
Added a valence.
Swapped the front clip for a 01-04. Trying to get as much space over the engine for a cross bar without cutting the hood.
Got lights.
