98 Ranger First Build
10,322
166
Cool! If the motor doesn't clear, you should move the outer tie rod heim below the lower tab and double shear it, then cut off the upper tab. Then I believe you can move the swinger assembly lower by the same amount without adversely affecting anything. (Key words are "I think" lol)
heezay
Smoke meth, hail satan.
Nov 27, 2011
2,252
1
buena park
Something looks off. Post a picture of the truck at full bump with the steering centered
socalkid92
2,484
7
National City, CA
I don't have another pic. I think it's just the angle of the picture and how close it is that makes the tires look messed up at full bump. In person it looks a lot better.
heezay
Nov 27, 2011
2,252
1
buena park
I’m talking about your tie rods hitting the frame at bump with any turning
socalkid92
2,484
7
National City, CA
Some updates. I got the shackles for the steering all done and welded up. Had to hold off on working on the steering until I dropped in the motor so I can see if the center link was going to clear.
I started getting the motor and transmission set up to put it in as one and then realized that I actually needed to get the cullhane flywheel to mate up the c4 to the 4.0sohc so I had to go pick one up.
Then I was going to mount the motor but ended up picking up some 3.0x10" 4 tube bypasses for the front and I needed to change up the shock mounts on one side
So I got all that done and finally got the motor and trans in and started on the trans crossmember.
Also decided to move up to 37s, got a BFG kr2 and some method wheels. I just need to find a few more tires.
Reactions: ljubera0250
382
what you doing with the old walkers and KO2 tires? What color are those walkers too? Dont seem to be all black. Almost look brown or bronze in center.
